| Message |
steering wheel and immediately found the problem, the brown connecter at the end of the cylinder had come loose on one side, i pushed it down and vroom engine started right up perfect when i turned the key, i tried a few times it worked perfect. i went upstairs to get some glue or tape to ape down the brown round connecter, and when wiggling it back down it came off completely. the white piece with the ball bearing and everything came out. i put it all back, white piece with bearing, then the spring, then the gold disc, then the brown connnecter, now it wont work at all. only thing that happens when i turn the key is the chime goes on. no power to anything, no radio, no ignition. please help this is my dd i need it running asap.
